Oil Pump Leak
Oil Pump Leak
'97 Camry 4 cylinder, 2.2L
I have watched a lot of video guides on how to change the oil pump gasket while I think I am probably capable of doing the repair I just do not have the tools or location for the task.
Is it possible to clean the area and seal it from the outside of the pump with some kind of sealer till I can pay somebody to do the repair.
Since this is a temporary solution will it break the first time driven or will it hold for a few months?
Leaking Oil Pump 97 Camry
Are you sure its the pump? Does the oil drip when the engine is running?
There oil every where in your photo. If the pump it typically is only from under the bulge of the timing cover.
The pump is under oil pressure making external sealing pretty much impossible.
Oil Pump Leak
Looks like the pump is leaking. The seal on the pump drive shaft starts to leak under oil pressure when the engine is on. The only fix is to install a new seal or pump.
One can buy a new seal separately, but not a new pump without also buying the housing the pump bolts on to. Point being its cheaper and easier to replace the seal. If doing this you will also need the preformed o'ring seal that goes around the pump body.
If you are driving the car, check the oil FREQUENTLY to get an idea of how much oil is leaking out!! This type of leak can cause all the engine oil to be lost in a relatively short period of time.
Thank you Toyomoho for an answer and helping to identify the leak. My car has been booked into the mechanics to have a timing belt kit installed .... timing bet, water pump and oil pump will all get done.
We were putting a quart of oil in the engine ever time we wanted to drive it 0.0
Have a great weekend.
Hello! Check the seals and oil pump for leaks, I had a problem due to poor quality oil. I had to clean the entire oil supply system, change the oil and filter. Here you can find Oil type for 5.9 Cummins, good options for your car.
We managed to get it into a mechanics and they have replaced the hole timing kit replaced including oil pump / seals .... Car is running awesome and no leaks!!!!
Even though we did not do the work ourselves, understanding the process and parts involved was a great benefit when communicating with the mechanic.
Thank you to everyone who took the time to help
