Oxygen sensor - 07 Camry 4 cyl
Old Dec 12, 2012 | 01:11 PM
jtmann's Avatar
Default Oxygen sensor - 07 Camry 4 cyl
Any guidance on how long these last/if or when to have tested or replace?
Thanks!
Old Dec 12, 2012 | 10:25 PM
The sensor is monitored by the cars engine computer. Typically if a problem the check engine light will illuminate.
Other then the check light coming on you might be concerned if the MPG takes significant drop although the cause could be many things.
Life may be 80-100K miles. Typically the heater built into the sensor fails.
adashjr
Dec 29, 2015 07:58 PM
MomInCA
May 24, 2011 04:06 PM
dmend
Jan 13, 2010 01:09 PM
appleredcamry
Jun 14, 2009 07:06 AM
