1994 camry 2200
will run fine for most of the time, distributor has been replaced, has a miss every so often found to be a bad plug wire, every now and then it will start running like it is completely out of time, then it will start running good again, happens every once in a while, any ideas what this could be?, have check resistance on coil cold and hot both test good, any help would be greatly appreciated
knock sensor is a separate part you can replace
threaded into the engine block under the inlet manifold
http://www.troublecodes.net/toyota/
ipod
Jun 17, 2009 03:44 AM
hondaelement
Mar 25, 2009 07:06 PM
