Browse all: Brakes
- Toyota Camry 4th, 5th, and 6th gen How to Replace Brake Master Cylinder
Browse all: Brakes
1997 Camry LE Front Brake Calipers Replacement - overseas
#12
Problem comming back
Well over 3 weeks on and today I started to get severe vibration at 60mph - eased off when I dropped to 40mph. Pulling harder to left and front left tyre was warmer than usual when I stopped. Symptoms are similar to when the problem started about 2 months ago so looks like it's back - if it follows pattern it will get more severe quickly i.e. burning pads. Garage have sourced replacement calipers from scrap yard so going to have to eliminate something sooner or later and work back up the line. Keep you posted on progress. Cheers.
#13
If you think the caliper is binding or frozen release brake line pressure via the bleeder screw and determine if this helps the situation.
Is so allow the problem with the brakes to repeat then loosen a brake fitting further upstream. Repeat this until you narrow down the problem area in the system.
Also sometimes the flexible lines running from the metal lines to the caliber can start to fail and cause break binding.
#14
Not the caliper - surprise!
Well swapped the caliper and hose and problem got worse. Refitted original caliper and still worse. So problem elsewhere. Reviewing economics of situation before any more work. Cheers.
Paul79UF
11-13-2021 08:26 AM
rapala13
10-03-2013 04:49 PM
slosr20
01-06-2013 07:03 PM
