2007 CE Vibration, tried all I know.
2007 CE Vibration, tried all I know. HELP!
I have a 2007 Camry CE, (4 Cyl) and it has recently started vibrating like a banshee at stop signs while in drive. Neutral it will occasionally vibrate, but nowhere near as bad. I do not see any correlation between engine temp and severity of vibration. Although it is worse at some times than others. Since it started this is what I have tried.
New spark plugs (iridium tipped)
All new dealer motor mounts
BG total top end service.
Mass air flow clean
Fuel system additive
Air filter
Oil change
Checked vacuum lines
Cleaned battery terminals
There are no engine codes, but the engine is definitely vibrating more than it should and is transferring that through the new motor mounts and into the drivers seat. I have tried everything that I can think of, can anyone give me some input on what to do, I dumped a grand into mounts so I really don't want to spend a ton of money in diagnostic fees if I don't have to. Thanks guys
Mass air flow clean
Air filter
Oil change
Also the idle rpm averages around 750 plus or minus 50 sometimes.
Also the rpm is around 750 plus or minus 50 rpm sometimes
Check ventilation one way check valve (PCV system). Air should be able to move out of engine but not into engine.
Idle RPM is OK, when the A/C is on and compressor working does the idle stay the same or drop?
Any pending codes.
Coil issues can cause vibration.
Any pending codes.
The mounts are all new, but I did check them for play again in case of a faulty one. They all seem to still be in good shape with no excessive movement.
How do I check the pcv valve?
