Sponsored by:
Sponsored by:
2006 Camry with rattling noise
Old 11-05-2015, 01:52 PM
Julie Chanek Carrasco's Avatar
Default 2006 Camry with rattling noise
Husbands 2006 camry started making a rattling sound under the hood on the passenger side. He leaves at 4:30am and doesn't get back til well after dark so I haven't been able to go out and look at it or record it. I will try to this evening. Have an appt to take it in on Monday to the mechanic. But was curious if it could be a belt? Upon starting and letting it idle..it rattles under the hood. Put it in drive and start to accelerate, you can hear it under the hood until you get up to speed and going, then its not hearable. Any ideas? I knows its pretty vague.
Old 11-06-2015, 04:09 PM
I was able to get a short video of under the hood today since I had to take it in for inspection and to get new tags for it. Any ideas before Monday?
Old 11-06-2015, 05:49 PM
Is this engine a 4 cylinder or 4-cylinder?
The water pump is in the area the camera was pointed.
Ask your husband to use a section of hose or other pipe as a stethoscope to narrow the area down.
Old 05-16-2018, 08:41 PM
cwil277's Avatar
Sounds like the water pump.
henryc
12-24-2012 03:08 AM
mcamry2007
09-10-2011 04:41 AM
stomper
03-17-2010 12:19 AM
ttommyser
10-27-2007 10:10 PM
henryc
05-13-2006 03:36 AM
Quick Reply: 2006 Camry with rattling noise
