2010 Corolla oil filter wrench
Old Jul 17, 2014 | 05:25 AM
53burb's Avatar
Default 2010 Corolla oil filter wrench
Guys,
I just got a 2010 Corolla & I changed the oil in it a couple of days ago. I was surprised that they are using a cartridge type of oil filter. I had to use a strap wrench to get the filter housing off. I did a search & found this tool. Does anyone know of a better tool? This one seems pretty good.
I just noticed this is a Camry forum....
Amazon.com : Oil Filter Cap Tool Toyota 64.5mm 3/8" Drive : Other Products : Everything Else Amazon.com : Oil Filter Cap Tool Toyota 64.5mm 3/8" Drive : Other Products : Everything Else
Old Jul 17, 2014 | 01:46 PM
Toyotaguy's Avatar
It's a good chance that one won't fit just right. The actual size you need is a 65mm.
Old Jul 17, 2014 | 11:12 PM
53burb's Avatar
thanks, I will check with them later to see if they have the one I need. I really like that design.
Old Jul 18, 2014 | 08:15 AM
Toyotaguy's Avatar
Yea man, I just hated to see you order that one and it not work. Toyota makes one specifically for them. They're pricy but very good quality.
Old Feb 4, 2015 | 11:31 PM
53burb's Avatar
Update: I ordered the one from Amazon that I mentioned because it wasn't too expensive & I could return it if necessary.. I tried it for fit & to see if I could loosen the housing without it slipping. It worked good. Thx everybody for the assistance.
Old Feb 5, 2015 | 12:12 AM
Thanks for the update, good to know.
Old Feb 23, 2015 | 09:11 PM
jeffkeryk's Avatar
I got one for my neighbor's 2012 Camry. Works like a charm. The filter housing was waaaaaay over-tightened.
Old Feb 25, 2015 | 10:17 PM
53burb's Avatar
good deal!!
Old May 29, 2015 | 04:44 PM
ryna88's Avatar
can you tell me why the oil filter housing on my 2010 camry is getting way to hard to remove?
thank you
Old May 30, 2015 | 08:02 AM
jeffkeryk's Avatar
Filter over tightened.
Filter cross threaded (not good)
Debris in filter threads.
