86 Camry LE
Old Jun 30, 2011 | 04:41 PM
D-ray's Avatar
Question 86 Camry LE
Does anyone know what . . .
My left wheel seems to try pull or torque more than the right wheel on acceleration, at even throttle as the transmission shifts up, very little on down shift, and when I back off the throttle. There was no torque steer for 5 years prior to two months ago, so I do not think it is that. There is no noise, grinding, clicking or clunking. A quick inspection with wheel of the ground showed no loose movement.
I would appreciate any info,
Thanks.
Old Jul 1, 2011 | 02:33 PM
Any work done since the chance, new tires, struts, etc?
Tire pressure and wear OK?
Old Jul 4, 2011 | 05:30 PM
D-ray's Avatar
Default Thanks for the reply . . .
Yes wear and pressure are good, I took another look and went over all joints and wear points. I found that the stabilizer to control arm bushing has some light deterioration and one small strand of the outer side of the bushing came off.
This could maybe cause the wheel to lead a bit, in-turn causing over torque. (or over-rotation)
