94 camry 6 cyl. Cold start problem
Old Jul 24, 2018 | 03:14 PM
Lesily's Avatar
Default 94 camry 6 cyl. Cold start problem
have a 94 camry with the 6 cyl engine. When cold it will absolutely not start. If i put a heater under it over night, or if its above like 70 degrees F, it starts, runs crappy until operating temp, then runs great. I cleaned the iac valve, even went to the salvage yard and got another one, cleaned it and put it on. Replaced temp sensor, mass air flow sensor, vacuum lines, and fuel pressure regulator. Still same problem. Check engine light comes and goes. Can someone please help me out?
Old Jul 25, 2018 | 12:32 PM
The temp sensor replaced was the ETC sensor for the computer?
How long does the check light stay on?
Is the engine getting fuel and ign spark when cold?
Does this engine have a distributor or does it have cam/crank sensors?
Old Jul 25, 2018 | 07:14 PM
Lesily's Avatar
Thank you for replying. The temp sensor is for the temp of the antifreeze. Its on the passenger side of the engine on top. The check engine light varies. Yes its getting fuel and spark and it has cam positioning sensor which was also replaced.
Old Jul 25, 2018 | 07:19 PM
Lesily's Avatar
Also sometimes, if i let it sit and idle too long, it runs crappy. I have to slowly accelerate or it cuts out.
Old Jul 26, 2018 | 11:02 AM
Try to read any codes present.
Note that this year and engine type is an ODBII hybrid. See link below:
https://www.justanswer.com/toyota/2f...camry-xle.html
Old Aug 3, 2018 | 11:49 PM
Lesily's Avatar
Ok, sorry it took me so long to get back to you. The codes are, p0300, p0302, p0303, p0340.
Old Aug 4, 2018 | 11:00 AM
The P0300, P0302 and P0303 codes are for misfires
The P0340 is for the camshaft position sensor. Check out this sensor (and wiring/connector) as a problem sensor can cause all of your engines issues..
Old Aug 5, 2018 | 01:30 PM
Lesily's Avatar
So, i ordered a camshaft position sensor. But im wondering if this part is temperature sensitive and would it be affected by the cold and then work once it is warmed up?
Old Aug 5, 2018 | 01:54 PM
The sensor is already temp sensitive. By design the sensors resistance changes with temp. This change is normal as long as its within design specifications. If outside the specs then there can be problems.
Old Aug 12, 2018 | 04:31 PM
Lesily's Avatar
Ok, so i replaced the camshaft positioning sensor and used the diagnostic tester to clear the codes. It still runs like crap when its first started until it gets to normal operating temp. Then it runs good so far. I havent driven it very far though..
