95 camry trans
Old Feb 5, 2012 | 02:57 PM
tity04's Avatar
Default 95 camry trans
it goes in reverse fine but in drive it starts off engine revs but car barely moves but when i picks up it runs ok but sometimes rumble. help please
Old Feb 5, 2012 | 09:25 PM
Have you checked the trans fluid level and condition of fluid?
Can you describe the rumble?
Have you tried shifting into 2 or 1st?
Could be an internal clutch pack or one-way clutch is slipping. If so the trans needs to be taken apart to repair.
Old Feb 6, 2012 | 07:07 PM
tity04's Avatar
yes checked fluid ok ,and 2 and 1 same thing ,,automatic
Old Feb 7, 2012 | 12:42 AM
It appears the issue is inside the trans. A transmission shop can run a few tests but would assume it needs to be overhauled or replaced.
If going to a shop just state the facts and let them make their own diagnosis. This will preclude them stating, you are correct regardless of what the problem really is.
vzehler
Oct 28, 2008 09:09 PM
nuttintoaboss
Jul 2, 2008 10:35 PM
speedfreak87
Dec 26, 2007 11:40 PM
perrylin
Dec 17, 2007 07:19 AM
colortv
Mar 29, 2007 12:01 AM
