Browse all: Engine Diagnostics
- Toyota Camry 4th, 5th, and 6th gen Engine Codes Diagnostic Guide
Guide to diagnose trouble and recommended solutions.
Auto Diagnostic Tool for Toyota
TOYOTA DENSO Diagnostic Tester-2
FUNCTION:
All type of Toyota(made after 2000) and Lexus included read code, clear
code , data flow, action testing and guard against theft initialization
function. And it also supports OBD-II.
CHARACTER:
1. Touchscreen & back lighting control
2. Easy & quick
3. User needn't worry about the after service since factory has an open
patio for maintenance.
hemeiling0811"at"hotmail"dot"com
FUNCTION:
CHARACTER:
2. Easy & quick
TOYOTA INTELLIGENT TESTER II
Description:
Intelligent Tester II for TOYOTA & LEXUS vehicles enables you to diagnose electronic control systems for engines, ABS's and airbags. This device realizes more accurate diagnosis through CAN communication which speed is 50 times faster than conventional.
Easy and fast USB connection will realize tight integration with Personal Computer (PC) based applications and systems.
Intelligent Tester II specifications:
Dimensions: 145mm (W) x 223mm (H) x 71mm (D)
Weight: Approx. 1380g
Source Voltage: DC10-32V
OS: Windows CE
CPU: Hitachi SH7727 128 MHz
RAM: 32MB
ROM: Flash: 32 MB, internal CF: 32MB
LCD display: 5.7 inch color STN (320x240), transparent type of 256 colors. Adjustable brightness/contrast
Touch panel Input: by finger or stylus pen
Electrical and electronic systems which can be diagnosed:
* Engine (Gas and Diesel).
* Hybrid Vehicle ECU.
* ECT (Electronic Control Transmission).
* EMPS (Electric Motor-assisted Power Steering).
* Toyota Free Tronic.
* ABS (Anti-Lock Braking System).
* Traction Control.
* Air Suspension.
* EMS (Electronic Modulated Suspension).
* EHPS (Electric-Hydraulic Power Steering Pump).
* AHC (Active Height Control Suspension).
* Sequental MT.
* Slide Roof.
* CCS (Cruise Control System).
* Air Conditioning.
* Airbag.
* Body.
* and much more
Features:
* Display Vehicle Current Data Parameters (Data List).
* Display Diagnosis Trouble Codes (DTC).
* Activate Relays, Solenoids, etc. (Active Test).
* Reprogram ECUs.
* Store All Data Parameters Before and/or After Problem Occurs (Snapshot).
* Display Voltage Signals from the Oscilloscope Probe and Voltage Meter Probe.
* Change of options in systems of body electronics.
IT2 firmware version: 2008.01
Intelligent Tester II software supports the following languages: English, German, French, Spanish, Italian, Chinese (simplified characters).
Set includes:
* Intelligent Tester II
* Voltage Meter Probe
* Oscilloscope Probe (2 pcs.)
* AC/DC Power Supply
* OBD-II cable
* Carrying case
Give a look at: http://www.efichip.com/index.php?-1628879905
There is also the operator's manual downloadble.
Description:
OS: Windows CE
RAM: 32MB
* Traction Control.
* Air Suspension.
* Sequental MT.
* Slide Roof.
* Air Conditioning.
* Airbag.
* Body.
* and much more
Features:
* Reprogram ECUs.
Set includes:
* OBD-II cable
* Carrying case
bapd77
08-16-2009 04:10 PM
2000, auto, camry, cars, daignostic, diagnostic, diagonstic, forum, forums, information, input, sale, tester, tools, toyota
