Bad Bulb Indicator - 99 Camry
Old May 16, 2013 | 03:11 PM
ahemsa's Avatar
Default Bad Bulb Indicator - 99 Camry
Hey all, I had a '97 Camry that I absolutely loved but someone decided that traffic lights didn't apply to them and thus totaled it for us. Fortunately nobody was hurt.
I was able to replace it with a '99 Camry which will be just fine, I just have one little problem. The dash indicator that says I have a burned out bulb comes on the first time I hit the brakes and stays on until I shut the car off.
Because the light only comes on when I press the brake pedal, I thought it reasonable that the problem might be a burned out brake light. Trouble is they seem to be burning! I have brake lights left and right of the trunk lid and the center mounted one. Are the trunk lid lights also supposed to light up when I hit the brakes? If so both sides are out.
From what I can tell every exterior bulb seems to be working just fine. Suggestions?
Old May 16, 2013 | 07:49 PM
The bulb sensor can turn the dash indicator on for other reasons then a burned out bulb.
Check bulb and socket electrical contacts for corrosion.
Check the dual filament bulbs (combo tail and brake bulb) for a failed filament that is now physically contacting the other filament.
Check the wiring wire harness for rear tail/brake lights where it transitions from the trunk to the trunk lid for damage due to flexing.
A bulb filament can gain in electrical resistance resulting in the sensor setting the dash light.
If all is OK, the sensor itself can fail.
kzargaroff
Jun 24, 2010 03:26 PM
1995YotaCamry
Oct 17, 2009 05:38 PM
nuttintoaboss
Jul 2, 2008 10:35 PM
NothingSound
Mar 6, 2008 07:42 PM
TrueRollers
Apr 30, 2007 03:48 AM
