A/C question
A/C question
I have a 94 Camry DX and just yesterday after I press the A/C button it starts flashing.
It does not blow very cold air.Is the light a "warning" lamp that there is a problem or just no freon in the system?
RE: A/C question
the reason the a/c button starts to flash is because the a/c compressor is not engauging witch is either a excissive clearance in the a/c clutch assy or low on refrigerant triggering the low pressure switch. yes their is a problem and the most likely is low on refrigerant (freon is no longer used only r134a).
