Can't back up
Old Jul 19, 2008 | 08:25 PM
TAR's Avatar
TAR
Default Can't back up
I have a 1990 camry 4cly,auto,200,000+miles Will not go into rev. All other gear seem to be ok. When I put it in rev. you can feel it change to that gear but will not move no matter how much gas you give it. filter changed about 45 days ago and looks clean on the stick. Need HELP[:@]
Old Jul 20, 2008 | 09:29 AM
Default RE: Can't back up
Could be the 1 to 2 or 2 to 3 shift valve. If so the valve can be removed for cleaning.
Old Jul 20, 2008 | 09:30 AM
Or a clutch, brake, etc. This requires removing the transmission.
Old Jul 20, 2008 | 12:50 PM
TAR's Avatar
TAR
Thanks, Where do I find the valves for cleaning? Are this elect. valves or spring ball valves?
Old Jul 20, 2008 | 04:41 PM
Can't post over 1 line without getting an error message.
Check your private messages for a link. Go to Gen 2 section of link for trans info.
Old Jul 20, 2008 | 04:43 PM
Check drivers side door for sticker with trans model number.
Old Jul 20, 2008 | 04:44 PM
Default RE: Can'
Could be A140E or A140L (or maybe H).
Default RE: Can'
If A140E, trans has electric shift solenoids but don't think this is the problem.
Old Jul 20, 2008 | 04:46 PM
Default RE: Can'
If may be the manual shift valves inside the valve body bolted to bottom of trans.
