Old Aug 25, 2015, 07:12 PM
How-Tos on this Topic
Browse all: Fuel System Guides
Print Wikipost
Catalytic converter readiness
Old Dec 20, 2007 | 01:41 PM
06grayrex's Avatar
Default Catalytic converter readiness
Hey all! Please excuse me for my lack of knowledge on toyotas, my mother has a 2000 camry 2.4 (I believe??) and when she tookit to have have emmissions tested, theyplugged the scan toolto the OBD2 port and saw thatthe catalytic converter was not ready yet, so they failed her.Any ideas on what could cause this? When I plug in my Actron scanner it tells me that there is no faults....I do not know if these 4 cylinder engines have any type of air injection system connected to the exhaust. Is it possible that the cat is bad already with a little over 60,000 miles on the clock. What is your experiences with this? Any advice would be greatly appreciated.
Thanks,
06grayrex
Old Dec 21, 2007 | 05:55 AM
pedro's Avatar
Default RE: Catalytic converter readiness
Was the car fully warmed? How long was it driven before being taken to inspection. This may be that the CAT and/or the O2 sensor(s)had not had enough time to fully heat.
Old Dec 22, 2007 | 11:54 AM
06grayrex's Avatar
Her Camry was driven about 15-20min prior to the inspection, so I know that car was at operating temp for both inspections. Still to this day no CELs have came on, however, her battery went dead and was replace about a month ago...So I really do not know if that would have caused a trouble code because of trying to start the car with a very low to dead battery......Tonight I will hook up my scanner again to see if any codes are present, but I doubt there will be.
Old Dec 25, 2007 | 11:22 AM
Toyota Technician's Avatar
cat readiness is if its ready to run the cat moniter (test) on it by the ecm now, i think the cat on that veh is 2 trip diagnostic meaning it take 2 trips around 30min long and some speed over 55 twice or u have a pending or history code that most aftermarket scanners will not show usually they just show present codes and no ur cat should be ok as long as u have been driving around for awhile with the cel on.
Old Dec 26, 2007 | 07:22 AM
06grayrex's Avatar
Cool...Thanks TT..My mother has an appointment with the local Toyota dealer tomarrow. I just tell her to have them clear that code and make sure that they do not try to up sell her on any unneeded services..
tvsdprasad
May 20, 2015 02:28 AM
rollingthunder6
Dec 30, 2009 09:15 PM
ntxgb
Feb 9, 2009 03:37 PM
caom999
Sep 22, 2008 09:37 AM
camry313
Mar 31, 2008 08:23 AM
