Old Aug 27, 2015, 12:31 PM
How-Tos on this Topic
Browse all: Electrical System
Print Wikipost
disconnected battery and reconnected and now the car is stalling
Old May 12, 2011 | 07:46 PM
camryarch's Avatar
Default disconnected battery and reconnected and now the car is stalling
i have a 2003 camry LE. as the title says the car stalls when stopping and idling is low. this is after i dc'd my battery... i checked and rechecked the connections and theyre ok. still stalls. any help is appreciated. thanks
Old May 12, 2011 | 10:43 PM
The problem may fix itself in short order. The issue is common after the battery is disconnected.
Old May 14, 2011 | 05:01 PM
UhOh's Avatar
^^^ agree. suggest going on a 50-100 mile drive w/o many stoplights.
If have problem afterwards, then worry about it.
Old May 15, 2011 | 10:39 AM
camryarch's Avatar
does it have to be 50-100 miles straight/non-stop? can it be shorter distances totalling 100? i drive around the block and stall several times... =/
Old May 15, 2011 | 02:57 PM
UhOh's Avatar
well, if you do it this way don't complain to us.
So pick out a pie shop that's 45 minutes away, have pie-a-la-mode and return ==> all done.
Old May 15, 2011 | 03:10 PM
With all electrical items off, start the engine cold and let it idle best you can until warmed up. When the engine is warm, running and parked, the radiator cooling fans will start to cycle on and off.
Turn on the AC and determine if the idle now adjusts to the AC compressor cycling on and off.
The strange engine idle operation is typically after the battery has been disconnected. The computer needs to "relearn." There is most likely nothing wrong with the car so don't try to fix anything at this time.
Old May 15, 2011 | 09:49 PM
camryarch's Avatar
i did EXACTLY as you said... worked like a charm! my guess is the idle had adjusted. i drove it around and it's not stalling anymore. Man, you really know your stuff!... thank you very much
Old May 16, 2011 | 10:12 AM
Glad to help.
Old Jul 5, 2012 | 09:37 AM
dw03camry's Avatar
Hi, I experienced this exact same problem when I disconnected my battery to replace my starter, but have tried all this techniques suggested to relearn the idle but my car is still doing the same thing. I have had several people suggest that it maybe the alternator and it is only charging at about 13.4v, but it just doesn't seem right to me as it acts normal all other times except for when it is at an idle. Any other suggestions as to what I should try/check?
Update: the low charge was due to the alternator belt being loose, it has been tightened but the stalling problem still persists.
Old Jul 5, 2012 | 11:34 AM
What year of car?
If the engine ran OK before disconnecting the battery would suggest continuing to wait on the idle returning to normal rather then start fixing problems which may be non-existent.
