Fixing 32"in 180w curved cree led light bar spot flood combo 10-30v offroad ute
I NEED TO FIX A FOG LIGHT TO BUMPER OF MY TOYOTA CAMRY 2004 GRANDE V6 MODEL CAR
WHAT ARE YOUR KIND OPINIONS ABOUT FIXING AS FOG LIGHT & OSARAM 2 x 9006 Led HB4 High Power 60W DRL Low Fog Beam Conversion Light Bulbs white 6k ?
1) 4D 32"IN 180W CURVED CREE LED WORK LIGHT BAR SPOT FLOOD COMBO 10-30V OFFROAD UTE
4D 32"IN 180W CURVED CREE LED WORK LIGHT BAR SPOT FLOOD COMBO 10-30V OFFROAD UTE | eBay
Camry 2004 will take the Electrical Load?
2) 2 x 9006 Led HB4 High Power 60W DRL Low Fog Beam Conversion Light Bulbs white 6k | eBay
180W = 15 amps. 60W = 5A times 2 = 10A. Total 25A
What else are you powering such as high wattage stereo amp?
Alternator output increases linearly until approx 2200 rpm. This means at engine idle it does put out that much.
Drive your car with all current electrical items on and set to the max. If the engine idle starts to drag it will go down much further with an additional 25A. You may need to idle at 1600-1800 to break even on the amp loads with these lights.
If you have a high output amp it may start to cut out at idle.
carid
12-08-2014 04:23 AM
peterliu2000
08-11-2010 11:15 PM
