The OutLaw Octane Booster
Hi ...
does any1 know where can i buy the outlaw octance booster ?? it comes in a 4 pack box 3.5 oz each.
I searched alot on the net to buy them but they are not available in most online stores ??
here u can see a picture of it >>> http://rares.multiply.com/reviews/item/4
advice please.
advice please.
oh man i bought that 4 pack from Autzone...dunno if it did anything...
i doubt it'll do much for your i4 engine.
you're better off just running regular with a fuel system cleaner during your oil change intervals.
Running higher octane (or in this case- adding octane booster) to an engine that is designed to run on regular grade fuel is a simply a waste of money. If you engine is pinging under load and you find that higher octane helps reduce the ping- you may have excessive carbon buildup in the combustion chambers. Octane Booster will only hide the symptoms in this case. You should have a decarb service done on your vehicle to remove as much carbon deposits as possible- which will then allow you to run regular octane fuel without pinging. The money you save on regular vs premium (or adding octane booster every tank) is well worth the expense of the decarb service in the long run. A decarb service is basically a service that injects detergent/solvents into the intake manifold while the engine is running.
J
J
wooow guys .. that wasn't for me .. its for a friend .. they use it for street racing adding it to 1/4 tank of fuel & it really works in increasing acceleration it is in a high demand specially in Saudia Arabia.
I've already had my decarb service done while cleaning my injectors.
Thank ya all... it's really wounderfull to havethe members to advice not to do something wrong or un necessary
haha yeah sefoam, but u gotta do a great job cleaning up the throttle body too!
street racing...haha crazy people.
And i think in other countries their octane numbers are generally higher than ours.
