Radiators
Old Jan 21, 2019 | 02:06 AM
Corvstang's Avatar
Default Radiators
Hello everyone
I have a 94 2.2 le
the previous owner replaced the radiator with a Denso 5/8" unit. It looks a week old or so and there is already a leak from the upper plastic tank crimp area below the radiator cap. The factory cap was used. I must replace it. Denso has a 1" thick core.... or is denso just garbage and you know of a better unit ? I'm new to toyotas.. first one!
Old Jan 21, 2019 | 11:26 AM
Denso good! Toyota owns part of the company which supplies parts to Toyota factories.
Make sure its leaking at the crimp as the upper tanks can crack.
What was the source of this Denso radiator, local or internet order? Has happened that shipped to home radiators can be bounced around in transit to the point of leaking at the seams. This is due to poor radiator shipping packaging.
A radiator shop (common job) or perhaps you could try to re-crimp the plastic top down to the core. It takes a special tool (try Ebay). There is an large o-ring between the core and top.
If replacing the radiator on as DIY, suggest buying locally and if available getting a life time guarantee. Radiators shipped to local parts stores are packed better to avoid damage. If the radiator leaks, take it back for a free replacement. Your brand selections at the local stores my be limited, but if the radiator leaks you have local recourse.
There are single and double row radiators. Unless towing, a single row works just fine.
C908
Jul 12, 2019 09:48 AM
MMA1991
Jan 17, 2017 10:55 PM
brianjrealtor
May 29, 2011 12:02 PM
FrankMacri
Oct 18, 2010 07:31 PM
Octapulse
Dec 4, 2008 06:46 PM
