rear bumping noise
Old Jan 16, 2007 | 02:11 AM
Mike Sexton's Avatar
Default rear bumping noise
I recently bought a '93 Camry. A really nice fixer upper. The car has a lot bumping noise when driving on rough roads. It has new struts on the rear. Other than bad struts, what would cause this problem?
Old Jan 16, 2007 | 02:56 AM
nodrogkam's Avatar
Default RE: rear bumping noise
bad strut mounts/boots.
loose sway bars
broken endlinks
worn bushings
Old Jan 31, 2007 | 08:10 AM
The problem was the sway bar bushings. The rear bushings were worn but the left front was missing altogether. I'm relacing the end links while I'm under there.
Old Jan 31, 2007 | 09:02 PM
nodrogkam's Avatar
good stuff. You're car will now handle better.
Old Feb 11, 2007 | 07:39 PM
Man, does it ever drive better. Thanks for the advice. Now I gotta get busy on the oil leaks. I guess the logical place to start would be the valve cover gasket.
marblehead2006
May 29, 2016 08:41 PM
yuke
Sep 20, 2008 09:22 AM
LtHorn
Oct 16, 2007 12:43 PM
yuke
Sep 18, 2007 10:36 AM
idreos
Jul 24, 2006 10:25 AM
