Replacing 100A fuse in 2003 Camry 4cyl
I have a blown 100A fuse under the hood fuse box and I need help or advise replacing it. I bought the fuse from the dealer and it is bolted underneath. Specifically, I need help how to get to those bolts. Do I have to unscrew the whole fuse box ? or there is another specific way or things I should look for?Any help is appreciated ... Thanks
Just an update on how to do this. I took it to Pepboys and the tech did it in front of me. You have to remove the airfilter and the battery. once you do that you get access to the 2 bolts that hold the fuse box. unbolt them and also there is a bolt on the side. So, basically remove the fuse box and then unclip the top part from the bottom part with the clips o nthe side to see the bolts that hold the 100A fuse. Its really tough to get in there as there are a lot of wires. Hope this helps someone.
Fixitvich
Mar 22, 2015 02:14 PM
camryvasaq
Jul 10, 2012 07:38 PM
