Side Mirror Housing Repair
Old Mar 31, 2013 | 07:58 PM
danstra's Avatar
Default Side Mirror Housing Repair
The prior owner must have hit something with the passenger side mirror because it was not connected at the front most point.
Between the car door and the housing is a metal plate that the housing screws into. The housing has three hollow posts that the metal plate screws into. When the prior owner damaged it the frontmost post had broken off within the housing at the end of the screw.
Upon inspection I noticed that there is another 3/4" of hollow post remaining so I decided to use the small piece of post that had broken off as a washer. I through-drilled the smaller piece. I bought a #12 X 1.5" replacement screw, threaded it through the "washer" and then screwed it down into the remaining part of the post that was still a part of the housing.
When I put it back together it was all as good as new.
With the cost of a new housing being around $50.00 and then paint I'm guessing that this quick repair saved me over $150.00.
dabruce15
Jan 3, 2012 12:17 AM
2000Toyz4Boyz
Oct 14, 2009 02:16 PM
boogz
Aug 8, 2007 01:13 AM
gorak
Aug 1, 2007 08:50 PM
av98
Nov 18, 2006 03:21 AM
