Steering acting up
Old Apr 2, 2008 | 12:39 PM
CKSMartin's Avatar
Default Steering acting up
Got a 91 Camry 4 cyclinder; had the engine rebuilt two years ago and it has less than 10,000 miles on the new engine.
This past week, the steering has started acting up; wheel turns fine, then it's hard to turn for a few inches, then easy again. It's like the pump is intermittantly working. I checked the fluids, and the pump was a little low, but not much, and I topped it off.
Could I have air in the pump or lines? Could I have some coponent in the actual rods, etc. going bad? Can a pump work one second, then fail then work again?
I should note that my Alternator, also rebuilt a couple of years ago, is also acting up- my lights dim a little and the A/c fan slows at idle, but no warning lights. I'm assuming the two problems are totally unrelated and it's time to replace the rebuilt alternator.
Old Apr 2, 2008 | 10:22 PM
Default RE: Steering acting up
Jack up the front of the car then turn the wheel, determine if it still binds. To purge the system of air turn the steering wheel lock to lock a few times.
Lights dim and A/C fan slows when at idle or at RPM over 1500ish?
npham28
Sep 14, 2012 04:47 PM
Eric_tovar
Jun 19, 2011 09:43 PM
trdcamrygracia
Aug 15, 2005 09:37 PM
Dan_Lemur
Jul 6, 2005 02:20 AM
