Too much oil???
Old May 16, 2010 | 08:17 PM
bs4u00's Avatar
Default Too much oil???
Quick question. I changed the engine oil in my 09 Camry today and put 5 qts in instead of 4.5. Will a .5 qt too much cause any damage?
Thanks!
Old May 17, 2010 | 11:12 AM
No, the engine will be OK with the extra 1/2 quart.
Old May 18, 2010 | 03:47 AM
Samohajo@yahoo.com's Avatar
I don't know where you are, so I don't know if you are using too much oil. If you have newer windows, you should not have drafts. Have the drafts repaired. To find out if you are using a lot of oil, call the oil supplier, and ask them what the average use is for an apartment your size in your area. They should also be able to run an analysis to show you how much oil you SHOULD be using, versus what you are using.
Old May 21, 2010 | 11:30 AM
bs4u00's Avatar
Ok, thanks Toyo. I won't worry about it.
2000Toyz4Boyz
Sep 26, 2009 02:16 AM
Rustydust
Sep 21, 2007 11:34 PM
blackCam99
Jul 25, 2007 10:00 PM
junior1124
Mar 2, 2007 12:34 AM
