tranny not shifting down, 95 Camry 2.2eng
Old Sep 25, 2006 | 01:49 AM
musemech's Avatar
Default tranny not shifting down, 95 Camry 2.2eng
Hi all,
My first port here, appreciate your help. I've got a 95 Camry, 4 cyl, AT. The tranny shifts through all the gears like your foot is barly on the pedal, at the minimum RPM. Completely kills any acceleration and will not shift down with foot on floor. I checked the kick down cable adj, its good and appears to be working. No vacuum input to be found, so I assume the controls are all electronic. I can shift it manually and it goes fine, no slips etc... Any thoughts on possible solutions? Thanks,
Kev
Old Sep 27, 2006 | 04:14 PM
lavalleemike's Avatar
Default RE: tranny not shifting down, 95 Camry 2.2eng
is the engine light on.. it may be the transmission solenoids but, usually the cel comes on.
Old Sep 27, 2006 | 10:35 PM
musemech's Avatar
No light. It comes on for the self check so I suspect it works. No codes either.
Old Sep 28, 2006 | 04:17 PM
I assume you have no grinding noise etc. i would have a tranny shop check it out. it could be the cable. or it could be a computer issue. but, have it checked out before it gets worse.
azrael_ak
Aug 15, 2013 03:15 AM
foscamry?
Mar 30, 2011 10:57 AM
Supra7joey
Oct 28, 2010 10:33 PM
carl455
Oct 20, 2010 10:13 PM
way2qwk4u
Mar 23, 2010 10:44 AM
