Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Hi flo cat converter
Old Feb 12, 2008 | 08:55 AM
94camguy's Avatar
Default Hi flo cat converter
Wel it turns out that after replacing the clamp holding the cat to the muffler (which passed somehow, dont ask me) withtheproperflangegasket, there is apparently a leak in the flex pipe which ties into the cat converter. Already a bad day. It fails inspection AFTER I fix the damn thing [:@]so I was told I would need to replace the entire cat converter, not just the flex pipe. And THIS is where opportunity arises. I plan on just patchin the spot for now, a hi flo cat wont pass in Mass. Theestimate to replace the cat was around $300, stock. If I can get a hi flo for a GMC van for $150-$200, I'm pretty sure I can do so for the camry. What do you guys think? I need a power increase in the thing anyways, will it make a noticable difference? I read that even a K&N intake will only give 6hp, that dont really seem worth it. How about the cat converter?
Old Feb 12, 2008 | 01:19 PM
Default RE: Hi flo cat converter
It is very common just to have the flex pipe replaced. A muffler shop can do this, auto parts shops also sell just the flex pipe.
Not up on high flow cats although have heard other Camry owners talk about them. You stated a high flow will not pass inspection.
Old Feb 13, 2008 | 12:03 PM
94camguy's Avatar
Yea it wont pass, so I figure if I can get my hands on one I'll patch or as you said fix the flex pipe, then install the hi flo after getting inspected. My father did the same with his van, new MAF, new intake, hi flo cat and performance muffler. (not a fart pipe.) So yea thanks good to know I can just replace the flex pipe.
Old Mar 31, 2008 | 08:15 AM
94camguy's Avatar
Okay, update: we got the thing to pass, after havong 3 more leaks we actually placed a piece of pipe into the rear of the converter to attach to the flange. Im guessing that created some bad back pressure because now there isnt a day that this thing doesnt wanna stall on me. I checked several places, a lot of people said clean the IAC. So I did. I got a considerable power boost but it still stalls. What do you think, is it that pipe?
rkimes11
Mar 10, 2009 02:40 PM
flynnagan
Jan 17, 2009 11:31 AM
Nightrider
Aug 23, 2008 12:25 PM
BrandonBrutality
Aug 19, 2008 08:50 AM
ronbob101
May 27, 2008 08:26 PM
