2002 Toyota Camry LE 4 cylinder check engine light error code p171 and p1035
Old Oct 11, 2016 | 11:48 PM
dalehall's Avatar
Default 2002 Toyota Camry LE 4 cylinder check engine light error code p171 and p1035
OK My check engine light came on so I took my car to autozone. The clerk said I needed a new Mass Airflow Sensor. I bought and installed a new airflow sensor. I had the check engine light turned off. After 5 minutes the light came back on.
I bought a Foxwell OBDII/ EOBD computer. I hooked this device up to the port underneath the dash. I received 2 codes one was P0171 and P1035. It should be noted I have no clue how to use this scanner that I bought.
I have replaced the O2 sensor on the manifold of the engine. What else should I do?
Old Oct 12, 2016 | 01:38 AM
dirty hands's Avatar
could be ghost readings
you have to clear the codes between each read and fix
if the reader cant clear ...
with radio code in hand if needed
disconnection of the battery terminals should clear the fault codes
you fixed the problem ,,so these codes should come back
Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop.
Read more at: https://www.obd-codes.com/p0135
Copyright OBD-Codes.com
general code when an 02 sensor fails
P0171 system too lean bank one
https://www.obd-codes.com/p0171
sconley
Mar 2, 2012 09:33 AM
sykesw
Jan 28, 2011 09:10 AM
FANtomCore
Aug 25, 2010 04:32 PM
PredatoryTrep
May 23, 2010 08:14 PM
mgoofy24
Sep 24, 2007 04:56 PM
