Nobody can figure this rattling out!! Please help 2014 Camry
Hello all. I have a 2014 Camry 2.5l LE Car with 130,000 miles. I have driven this car with mechanics to find out what this rattling is and it either doesn’t show or it’s faint while they are with me, I’ll explain.
The vehicle only makes this rattle after warming up and being driven for at least 15-20 mins and it’s only while in drive and it’s makes a lower end rattle sound in the passenger side when I do slower accelerations. It will not rattle if I try to accelerate faster and it seems to do it after the car has reached its next gear ( in between automatic shifting a certain speeds). I noticed if I find the perfect resting point for my foot while on the freeway and I keep it at a consistent speed without trying to speed up but also not releasing the gas that I can get it to rattle for sometime, otherwise it’s temporary. It doesn’t make the sound while in idle, if I press the peddle in idle there is no noise either and it seems to be much more emphasized if it’s a hot summer day after the car heats up more. I was told poss timing chain tensioner but no one is certain as of yet. Thanks for your time
I had same issue. For me it was the water pump. It wasn’t leaking any coolant prior to going out. The impeller was hitting the inside of the water pump housing causing the rattling sound. Eventually the housing cracked causing the pulley to break off and ate the belt.
zicowhite
Apr 15, 2025 03:42 PM
