Innovative Developments of Thrive Making It Better for DVD Playback
Old Sep 26, 2012 | 05:56 AM
ivan walker's Avatar
Default Innovative Developments of Thrive Making It Better for DVD Playback
Apart from plenty of mainstream tablets like iPad, Kindle Fire, at this time one more quite excellent mobile entertainment hub will be shared for you: Toshiba Thrive.
On the subject of the Thrive gadget, definitely there are a slew ofkiller features included: giant and high resolution screen, high performance dual-core cpu, over-long battery life and perfect sound quality. For Toshiba Thrive keepers, of late if you have updated its OS to Ice Cream Sandwich, you are guaranteed to find that its video and audio efficiency is significantly boosted. Undoubtedly, all fresh developments on Thrive make it a much better machine for multimedia enjoyment, especially for hi-def DVD playback.
As you probably know, Thrive supports 1080p video playback and usual movies can be successfully read and enjoyed. However, DVD movies are considered as a exception. Owing to the nonsupport of DVD drive, the means to play DVD on Thrive has been blocked. Hence, if you want to make that happen, a program called DVD to Thrive converter is necessary. With such sort of application, you can rip DVD to Thrive suitable video so as to let you send DVD videos to Thrive for playback without any limitations. Furthermore, to show you a improved movie enjoyment, it allows you to pick up subtitles and audio tracks for output based on your personal language preference. Here all things you need to prepare for doing the DVD to Thrive conversion will be detailed down below.
1. Your Toshiba Thrive.
2. The USB connection cable matched your Thrive
3. Windows-based computer for doing the DVD conversion
4. DVD-ROM. If you want to transfer the content in a DVD disc to your Thrive, you need to make ready for a pc with DVD drive included. If you are using an ultrabook, an external with DVD drive is a must.
5. Conversion program: DVD to Thrive converter
6. Your collected DVD movies
Since all are ready, let us commence the full guide on how to rip DVD to Thrive.
For starters, when you download, install and also work the DVD to Thrive converter on your computer, you can hit "Load DVD" button to insert the DVD movies.
Secondly, we realize that the Thrive reads video in MP4 well, so you can go to program "Profile" menu to select a Thrive compatible format as the output.
Lastly, press the bottom-right button "Convert" to play DVD on Thrive video.
When the complete conversion is finished, all ripped files can be uploaded to Thrive for excitement. So, do not hesitate to immerse yourself into those brilliant movies making use of your Thrive.
ivan walker
Oct 12, 2012 01:21 AM
