Low battery warning when I put into ev mode
Old Mar 7, 2023 | 01:48 PM
melvin4503's Avatar
Default Low battery warning when I put into ev mode
When I first start the car and try to.engage ev mode the low battery warning comes on.. but after driving awhile I can change it into ev mode .. is this a 12 volt warning on my 12 volt system or ?? Is it related to the main battery system . ( 2014 camry hybrid xle model )
Old Mar 7, 2023 | 03:37 PM
Main battery.
Do you have the trans in neutral?
Old Mar 7, 2023 | 06:15 PM
melvin4503's Avatar
I am in park too start with but when it is running awhile it's in drive forward then it engages to take the command to change to ev mode !! The low battery warning is on the dash in the middle of the speedometer area
Old Mar 7, 2023 | 08:41 PM
Is this the dash icon shaped like a battery which is illuminating?
Old Mar 8, 2023 | 04:37 AM
melvin4503's Avatar
Reply -- no its a full English sentence warning so after awhile I can engage the ev mode . Just wondering if it's main battery being low and then charging a little after awhile and it is able too engage then after taking a charge from the engine after driving !!!
Old Mar 8, 2023 | 01:57 PM
Main hybrid battery.
The battery needs to have a certain % charge to engage EV mode. If not having this then the warning comes on and it doesn't engage. Once the battery has enough charge EV mode will engage.
Appears to be normal system operation.
HookedOnCamry
Aug 11, 2021 03:06 PM
Johnson Adebola
Apr 19, 2021 05:10 PM
spkay31
Apr 2, 2020 01:09 PM
Rebecca Tenniel
Apr 24, 2018 11:31 PM
Newcamry16
Jul 1, 2017 03:09 PM
