Theoretically what would need to be done to a 2007 camry to 2jz swap it
Old Mar 20, 2023 | 12:25 PM
ajaw's Avatar
Default Theoretically what would need to be done to a 2007 camry to 2jz swap it
always been a joke between me and my buds that my camry is 2jz swapped
Old Mar 20, 2023 | 02:59 PM
Check out the Camry swap into a 1993.
https://www.reddit.com/r/Camry/comme...s_1993_toyota/
First you have to fit the engine and trans into the chassis. The engine weighs more and the engine/trans combo will shift the chassis weight. This may need to be accounted for with the suspension. The combination is rear wheel drive plus what to about the front wheel axle setup that is designed for front wheel drive. Then comes the wiring and electronics. Some older Camry were 4 wheel drive but not a 2007. This assumes the older Camry rear axle will handle the HP.
Old Jun 22, 2023 | 12:33 AM
DaddyM97's Avatar
Default 2004 Toyota Camry Swap
Would it be plausible to drop a 2ZZ-GE Engine in my 04 Camry if my engine ever went out on me?
09RedCam
May 1, 2022 12:42 PM
Daniel Jacob Wagner
Jan 17, 2021 10:45 PM
Chrismexicali
Jan 17, 2017 01:38 PM
98 camry
Oct 10, 2015 11:02 PM
mr_yashua
Jun 22, 2009 11:29 AM
