brake have problem
Old May 20, 2008 | 11:59 AM
johnnycamry 1995dl's Avatar
Default brake have problem
hi guest, I have 1995 camry le4cly. everyday I first driving car. the first few stop the car have brake noise. like need change brake. I take off the tire check both in side brake. the brake is very thick. put back tire still have noise. Is anyone have same problem
Old May 21, 2008 | 11:56 AM
Default RE: brake have problem
The back brakes are drums. The inside surface of the drum where the shoes touch can become glazed, this can cause the noise. Remove the drum and wash the dust off, don't blow it as it can contain asbestos. Use 150 grit sand paper to brake up the surface glaze. Sand around the drum, not back and forth across it.
Can also be excessive brake dust between shoe and drum. If so wash this off.
Check the shoes and determine where they are wearing, wear should be on most of the shoe not just center.
Check all of the brake hardware for loose items that can vibrate when the brakes are applied.
Old Jun 1, 2008 | 11:32 AM
fuwa's Avatar
the sound come from front right handside brake.
jkuehnert
Mar 8, 2014 08:20 PM
Szolga
Jul 12, 2011 06:49 PM
johnnycamry 1995dl
Jun 1, 2008 11:30 AM
Canuck
Jan 3, 2007 03:39 PM
