front control arms on 94 Camry
Old Jan 8, 2010 | 06:12 PM
poomba's Avatar
Default front control arms on 94 Camry
how much is it gon be to replace front control arms on 94 Toyota Camry? . I found really cheap car on craigslist for $600 the guy told me needs front control arms..and new brakes. Is it worth it?
http://boise.craigslist.org/ctd/1516130721.html
Old Jan 8, 2010 | 08:16 PM
Are you doing the work yourself or a shop?
Typically the front control arm bushings go bad. This requires taking the front suspension apart to get the arm unbolted from the car. An after market arm is around $120 ea. The bushings can also be replaced at around $20 each (2 per arm) but this requires additional labor.
In doing the job the brake parts need to be removed thus this would reduce labor costs for a front brake job.
Depending on the shops labor rate guessing!! costs at $800+. The job is not difficult but requires labor.
A shop that deals with Camry should be able to give a reasonable estimate.
The ad lists a lot of "stuff" most it was standard equipment for LE. The car has the optional V6 engine. Thus it is a Camry LE with V6 option.
If you don't no car mechanics suggest you have mechanic go over the car. If you are having a shop do the work repair costs can really add up fast!
Old Jan 9, 2010 | 12:41 AM
poomba's Avatar
ooook! thanks man
jcott948
Oct 5, 2016 10:40 AM
beattyrd
Sep 2, 2009 10:28 AM
beige97camry
Apr 11, 2009 03:38 PM
kdp
Mar 16, 2009 09:47 AM
72AMX
Feb 23, 2008 04:10 PM
