Old Aug 26, 2015, 01:15 PM
How-Tos on this Topic
Browse all: Brakes
Print Wikipost
Just bought the 2010 camry and a few questions about changing the wheels
Old Jul 31, 2009 | 08:13 AM
deepen03's Avatar
Default Just bought the 2010 camry and a few questions about changing the wheels
So we bought the 2010 camry le, and they only had the models with the hubcaps. The ones with the allow wheels were like in a different package. To upgrade it was like around 900 bucks. So i was just going to buy some wheels on ebay.
I found these: http://cgi.ebay.com/ebaymotors/16-20...Q5fAccessories
now those are oem, so i can just replace them with my current steel rim and hubcaps right? it should just be a quick change right? the stock wheels are 16" and the ebay ones are 16", so i dont even need new tires right?
Old Jul 31, 2009 | 09:39 PM
mostlystock's Avatar
make sure the rim width is similar, if it is too wide the stock tirea will not fit, but 16 in tires will fit on aftermarket 16 in wheels, also make sure they transfer your tpms sensors over.
Old Aug 1, 2009 | 10:33 AM
deepen03's Avatar
ok well the ebay ones say 16x6.5". so that means the width is 6.5 inch right?
and do you know what the stock width is on the 2010?
and do they transfer the tpms sensors at any tire place? like walmart, sts firestone or pepboys?
Old Aug 6, 2009 | 11:04 AM
deepen03's Avatar
anyone have any ideas? i don't want to buy these and then have to change the tires if they are too wide for my stock tires.
Old Aug 7, 2009 | 10:48 AM
bullisbm's Avatar
Based off a quick internet search. It looks like the 2010 Camry has the following sizes
# Front Wheel Size (in): 16 x 6.5
# Front Wheel Size (in): 17 x - TBD -
# Front Wheel Size (in): 16 x - TBD -
# Front Wheel Size (in): 18 x - TBD -
# Rear Wheel Size (in): 16 x 6.5
# Rear Wheel Size (in): 17 x - TBD -
# Rear Wheel Size (in): 16 x - TBD -
# Rear Wheel Size (in): 18 x - TBD -
# Spare Wheel Size (in): 17 x - TBD -
So I would say it currently has 16 x 6.5, can't tell you the offsets.
Old Aug 8, 2009 | 11:05 AM
deepen03's Avatar
yea i did a search just now: http://pressroom.toyota.com/pr/tms/t...Info_final.pdf
in that article, it says that the LE (mine) has 16 x 6.5" wheels. so i can use those wheels from ebay on my current tires.
Old May 12, 2012 | 10:38 PM
russc46's Avatar
i have an 11 camry, bought wheels from a 2007 camry, 16 inch, and they hit the disc brakes on the front, trying to figure out how big of a spacer i should buy.
Dspahn
May 9, 2015 11:31 PM
Jayhem
Aug 16, 2012 02:07 PM
outdoneyou
Sep 1, 2007 05:34 PM
flyboi
Aug 15, 2007 02:17 PM
seanyk17
Aug 15, 2007 12:35 AM
