pad & rotor combo question?
Old Apr 18, 2009 | 08:46 PM
NXRACER's Avatar
Default pad & rotor combo question?
--> I got a '92 Cam, I'm tight for cash, I want to know what would happen I if I get high-end pads from EBC combined with a Duralast Gold rotor or visa/versa because I dont have enough $ to buy pads & rotors from EBC @ this point.
-also post what brake combos or packages you have for your Cam here too-
Old Apr 19, 2009 | 05:22 PM
The Duralast is supposed to be the best Autozone has. Should work ok.
If just street driving and your short on money check if Autozone has cheaper ceramic pads.
Old Apr 19, 2009 | 11:19 PM
NXRACER's Avatar
---> If they can hold up to daily heel&toe use long enough to afford a full EBC front break set.
i was running semi/ceramic prostop pads on a slightly worn STOCK rotor !!! lost those little anti-squeel springs too so when they get hot from the sun or from a 30+ minute drive it sounds like a big rig. freaks peds & other drivers out! FUNNY AS @#%$
supraman7mgte
Oct 7, 2013 08:16 PM
RL-521
Jun 9, 2009 11:36 AM
doodledodge1
Jan 31, 2009 11:49 AM
jtsnew72
Oct 20, 2007 06:45 AM
Slippy
May 12, 2006 12:30 PM
