question about 20"s on 2005 Camry
Old Feb 24, 2006 | 09:27 PM
KillaCam05's Avatar
Default question about 20"s on 2005 Camry
hey whats up guys im a new member to the forum and i recently purchased a silver 05 Camry LE, and i saw these rims and i fell in love with them, but im not sure if they will match my car, the rims are from SSW and its called the Multyspoke, if anyone has pictures of that size and similar looking rims on a 5th gen Cam please post them.......thanx...
Tristan
Old Feb 24, 2006 | 10:41 PM
jasmtz531's Avatar
Default RE: question about 20"s on 2005 Camry
20s wont even come close to fitting on a camry. Besides... it would kill you braking power, speedo accuracy, acceleration, and you cant hit a bump with out busting them up. Whats the point.
-Jason
Old Feb 24, 2006 | 11:42 PM
KillaCam05's Avatar
so do u think 18's will do it?
Old Feb 25, 2006 | 05:46 AM
trdcamrygracia's Avatar
i saw few gen5 with 20"....19" will fit for sure.....
Old Feb 25, 2006 | 12:03 PM
rin's Avatar
rin
If you want 'the look' go for 19" or 20" wheels, 20" are a must if youre going with the polished lip look as large lips and fake dish make wheels look small.
you will have ZERO fittament problems as long as you purchase a set of wheels with correct offset and width. the best way to do this is to test fit wheels. as a starter, a 8" wide wheel with about +45-48mm offset should fit, but dont quote me, im a gen3 owner and the standard offset has changed 12mm since then.
your speedo will be off, as you wont find a tyre that will keep the original rotating diameter at the larger 20" wheel size. a minor problem.
get some lowering springs if you want 'the look' remember =)
gpulse
Dec 3, 2008 06:09 PM
ras2247
Oct 15, 2008 05:08 PM
ras2247
Oct 14, 2008 10:59 PM
Camry05WS
Sep 19, 2008 02:00 PM
supermancjl
Feb 11, 2008 05:13 AM
