SWAY BAR BUSHING SIZE
Old Oct 15, 2007 | 09:12 PM
PAID4's Avatar
Default SWAY BAR BUSHING SIZE
[:@]I've just replaced my rear sway bar bushings with 17mm ones that the dealer said would fit my "95 LE 2 door. When I removed the old ones, 15 was stamped (molded) into them, the new ones were stamped 17 (17mm, I guess?) When I looked around for jobber parts, before buying them from the "stealership", I was told there were 2 sizes 15mm/16mm and 17mm. All this to say that the "rattle" is still there, although it might be a little less noticeable... Are there actually different sizes, I asked the parts guy to double check the part number, and he told me that 17mm was the only listing for my car. What is the next most likely culprit ? I did the sway bar bushings because they were the easiest to do first
Thanks in advance for any advice..
nb99camry
Apr 9, 2012 09:09 AM
jscudder
May 15, 2011 10:12 PM
pnmid
Aug 17, 2008 08:44 PM
emberglo
Nov 13, 2007 07:15 AM
Jeremy_B
Sep 9, 2007 01:00 PM
