Need help identifying part.
This is connected next to right side cooling fan ( on a 2000 camry le 2.2 4cyl sedan), connected to a sensor (i think) in the radiator. Im thinking its for the coolant temperature sensor but maybe not because the sensor is higher up on the radiator hose instead of under the radiator. if someone could help me out and tell me what connects into here id really appreciated it
artemtroy
05-23-2013 02:15 AM
