2009 toyota camry wire location and color
Old 11-08-2008, 10:22 PM
derk's Avatar
Default 2009 toyota camry wire location and color
I've searched the forum for this info but have been unable to find it all in one place or for a 2009.
2009 Toyota Camry SE 4 cylinder
Can someone please give me the following info:
Colo + or - and location, often I find more then one color
example tac wire location on airbag factory plug there
are two black with silver wires.
1. Lock wire
2. Unlock wire
3. Factory Arm
4. Factory Disarm
5. Tac wire (which one)
6. Door trigger
7. Dome Light
8. Trunk Release (electric one)
9. Parking lights (which will flash when the alarm is armed)
10. Brake
11. Horn (I assume this is a relay)
12. hood trigger, is there one inside?
Note: 2005 -2009 Camry's appear to have similar body styles but from reading the forum some wire color and locations have changed.
The VSS or Vehicle Speed Sensor used for Navigation systems is said to be the violet and silver wire on the club plug, there are (2)of these wires. I was also told the purple wire on the radio harness is the VSS, Crutchfield gave me this info so I used that wire.
Thank you
Old 07-05-2009, 04:00 PM
tester272001's Avatar
Default wiring for 2009 camry se
I found this elsewhere (today) but have not verified yet:
Battery
BLACK
IGNITION SWITCH HARNESS
Ignition 1
YELLOW
Starter 1
BLUE
All Door Trigger
BROWN
AT VEHICLE FUSEBOX
Domelight Super
BROWN
AT VEHICLE FUSEBOX
LF Latch
BLUE
AT BECU MODULE IN VEHICLE FUSEBOX
RF Latch
YELLOW
LR Latch
LIGHT GREEN
AT VEHICLE FUSE BOX
RR Latch
GRAY
Trunk Trigger
WHITE
Hood Trigger
RED
AT VEHICLE HOOD PIN SWITCH
Alarm Disarm
BLUE
INGITION SWITCH HARNESS (KEY IN SENSE WIRE)
Parking Lights
BLACK
Battery
BLACK
Ignition 1
YELLOW
Ignition 2
PINK
Accessory 1
WHITE
Starter 1
BLUE
Starter 2
GRAY
Anti-Theft Type
UNIVERSAL IMMOBILIZER
Anti-Theft Descript
THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense
BLUE
Tachometer
BLACK
(AC)
AT DATALINK CONNECTOR UNDER DRIVER DASH
Speed Sense
VIOLET
(AC)
RADIO HARNESS
Parking Lights
BLACK
Brake Lights
WHITE
AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights
RED
IN HARNESS IN DRIVER KICKPANEL
Horn
WHITE
AT VEHICLE FUSE BOX
Miguel Farina
09-20-2014 05:43 PM
mrbeebs
02-09-2012 02:49 PM
Synomenon
06-18-2011 07:42 AM
09camryfastmpg
02-05-2010 09:56 PM
trdcamrygracia
11-03-2007 01:38 AM
Quick Reply: 2009 toyota camry wire location and color
