Installing backup cam in '03 camry
Wiring runs down both sides of chassis where rocker panels would be. Remove trim and pull back carpet on side to find it. Trunk wiring runs down drivers side.
Find trunk wire harness, then route wire next to it. Remove lower rear seat, then route down drivers side. Then route behind drivers side kick panel and up under dash. Assume will need to remove radio to connect but easy enough once trim is removed. Snake wiring to radio from under dash.
raichean
05-26-2015 01:30 AM
