02 CAmry codes P1120 & P1121
Old 01-05-2017, 04:46 PM
andy2867's Avatar
Lightbulb 02 CAmry codes P1120 & P1121
My daughter's 02 Camry just started getting these 2 codes. Symptoms are a slow response when the throttle pedal is pressed. I read somewhere else to check voltages at the TPS on the pedal. However, that post was 4 years ago and the individual never reposted the voltage. Hopefully, someone one can help. Below are the voltages I got from back probing the TPS. all measurement taking with the key switch on. Just want to make sure its the TPS.
VPA/Blue-yellow wire - Pedal at idle no voltage. Pushing down on pedal voltage climbs to 3.28
VPA2/White-Red - Pedal at idle voltage read 1.54 detected. Pushing down on pedal voltage climbs to 4.21.
VCP/Red wire & VCP2/ Black-Red - 5.1 voltage at all pedal positions.
Old 01-05-2017, 06:22 PM
dirty hands's Avatar
this a 4 or a V6
now need someone with the repair manual data to verify readings
this site you have to scroll though every page of the 2001 camry pdf to find information required
http://manuals.co/workshop/toyota/camry
02 toyota camry e manuals and most other repair manual sites are not free
haynes US online download
https://haynes.com/en-us/toyota-camr...-online-manual
Old 01-05-2017, 06:33 PM
andy2867's Avatar
It's a V6
Old 01-05-2017, 06:59 PM
andy2867's Avatar
All the TPS troubleshooting I see deals with the TPS on the throttle body. This car may have a sensor on the throttle body, but it also has a sensor on the accelerator pedal as well and that the one I tested.
Old 01-05-2017, 08:05 PM
P1121 = APS sensor faulty. Harness has open, short or poor conductivity.
P1120 means ECU has shut down power to throttle motor.
VPA voltage
Released 0.4-1.2v
Depressed 3.0-4.6v
VPA2
0.9-2.3v
3.4-5.0v
The pedal has two potentiometers gained together (VPA and VPA2 are the wipers).
No power at VPA released means a problem.
Old 01-05-2017, 09:00 PM
thanks ...found the pedal sensor picture
too much electronics on cars these days
Old 01-06-2017, 11:02 PM
andy2867's Avatar
VPA voltage
Released 0.4-1.2v
Depressed 3.0-4.6v
VPA2
0.9-2.3v
3.4-5.0v
No power to the VPA (Would that mean a faulty sensor?)
Old 01-07-2017, 12:24 PM
Based on the criteria provided by Toyota yes.
P1121 is the actual trouble code. See list of possible faults in your above post.
P1120 is a response to P1121. This being the ECU shut down power throttle motor.
vrubinsky
05-30-2015 08:44 AM
DeltaNu1142
03-28-2013 08:30 PM
chrisdupe
08-05-2009 12:30 AM
shoponline
02-16-2009 05:58 PM
Quick Reply: 02 CAmry codes P1120 & P1121
