2010 Camry SE throttle body cleaning
Old 11-03-2010, 09:31 PM
rbmead's Avatar
Default 2010 Camry SE throttle body cleaning
What is the best way to clean the throttle body on a 2010 Camry SE with the 2AR-FE (2.5l inline 4) engine??
Is it OK to push the throttle plate aside while cleaning with a rag/old toothbrush?
I plan to use Sea Foam Deep Creep cleaner.
Old 11-04-2010, 12:06 PM
This seems a bit early for cleaning the throttle body.
The Toyotanation website may have something.
Not up on this engine design, but suggest you do some research first. Some auto manufacturers throttle bores were coated with a thin material that could be damaged when cleaning.
In the past this was not the case for Camry but Toyota may have decided to do something different on this engine, never know.
There have been a few recalls and other issues for this year of Camry due to sticking throttle and slow throttle return.
DIYDad
05-10-2019 02:47 AM
rustydud
12-28-2011 12:02 PM
hardyrxp
03-31-2010 11:09 AM
TwoSlo
09-08-2009 09:51 AM
marc780
04-10-2006 06:22 PM
Quick Reply: 2010 Camry SE throttle body cleaning
