Brake lights not coming on when pedal pressed.
Old 03-06-2017, 12:58 PM
StephiesMan's Avatar
Default Brake lights not coming on when pedal pressed.
My tail lights will come on when I turn the headlights on, but when I press the pedal, nothing happens. When I turn the headlights off, the tail lights go off and still, nothing happens.
The fuses are all good.
The lights do not turn off when I press the pedal. They do not dim or light up brighter and it is not the bulbs, because I checked them lol.
please help!
Old 03-06-2017, 04:40 PM
dirty hands's Avatar
what year camry ?
up under the dash
there is a stop light activation switch on the brake pedal
adjustable and replaceable
Attached Thumbnails Brake lights not coming on when pedal pressed.-images.png   Brake lights not coming on when pedal pressed.-beck-arnley-brake-light-switch-201-1618.jpg
Old 03-06-2017, 08:37 PM
Originally Posted by dirty hands
what year camry ?
up under the dash
It's a 1995 2.2
Old 03-06-2017, 09:17 PM
1995 camry stop light activation switch
should be like the metal thread and nut image
Old 03-06-2017, 10:18 PM
Old 03-07-2017, 12:53 PM
I replaced the switch and nothing happened :/
Old 03-07-2017, 02:43 PM
that switch has 12 volts to the bulbs
did you do the adjustment at the pedal so the switch fully releases when pedal depressed
brake light bulb has two elements inside
fit a new one to be sure
Attached Thumbnails Brake lights not coming on when pedal pressed.-img138-37-400.jpg
Old 03-07-2017, 03:21 PM
Returned the switch at Autozone and they gave me another one and it worked.. guess I got the lemon? Thank you for the help!!
Old 03-07-2017, 04:19 PM
good to know the pedal switch resolved the problem
thank you for the feed back
CamryLastFoureverNever
03-16-2015 07:57 PM
jetfire
07-03-2009 02:34 AM
camry34
05-07-2009 05:28 PM
swaggalikeus
04-24-2009 10:03 AM
mixta
04-06-2007 01:39 PM
Quick Reply: Brake lights not coming on when pedal pressed.
