1998 camry no spark won"t start 4cyl
Old 03-14-2009, 12:40 PM
fred's Avatar
Default 1998 camry no spark won"t start 4cyl
I have a 1998 camry 4cyl 4spd with no spark that won"t start. What shoud I be looking at
Old 03-14-2009, 01:48 PM
Does the engine have a distributor cap? If so determine if the timing belt broke. Remove the distributor cap and check the rotor turns when the engine cranks.
With the cap off, rotate the engine crank pulley to the 0 degree mark with the No 1 piston at TDC. Determine if the rotor is at the No 1 plug wire electrode. No 1 cylinder is closest to the timing belt.
Does this engine have one coil or two?
Check all fuses such as EFI, AM2,
Old 03-14-2009, 08:17 PM
89poscamry's Avatar
might need a new ignition coil. when the last time u changed the distributor cap, rotor button, plugs, and wires?
Old 03-15-2009, 07:07 PM
sylvsm's Avatar
no electricity come out of the wire witch go to the distributor
umaree67
05-11-2021 05:12 PM
manty1
04-10-2013 04:54 AM
organica
07-17-2011 09:15 AM
peterliu2000
08-11-2010 11:15 PM
Shake_Zula
02-20-2010 08:59 PM
Quick Reply: 1998 camry no spark won"t start 4cyl
