Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE
Old 10-07-2016, 01:16 PM
jjohns2011's Avatar
Default Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE
I have a 2011 Camry SE that I'm keeping forever. Basically the goal is turn this car into the ultimate sleeper. The 2UR-GSE is the V8 that is used in the Lexus IS-F and RC-F. Could this engine + drive train fit my Camry?
Old 10-07-2016, 03:39 PM
dirty hands's Avatar
images on that motor shows up.. as a rear wheel drive set up ?
out of a lexus ?
the v8 motor without a gearbox
sitting in a lexus engine bay
2011 camry engine bay
Attached Thumbnails Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE-index.jpg   Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE-img_1928.jpg   Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE-2010-toyota-camry-sedan-base-4dr-sedan-exterior-engine.png.jpg
Old 10-07-2016, 06:14 PM
Anything is possible. However this would be a LOT of work if even possible.
If you want more HP, then investigate increasing the current engines HP.
Old 10-08-2016, 01:00 AM
one obvious body modification required
the shock towers of the camry chassis have to come forward
camry chassis extended forward heaps
moulds and fabricate fiberglass front panels from windscreen
gearbox selection limited if one intends east west set up for that v8 motor
Attached Thumbnails Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE-index.jpg   Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE-images.jpg
peb_hlub
10-10-2011 10:40 PM
Lakeron
06-04-2011 11:29 AM
1994"Mr Reliable"Toyota Camry
11-30-2010 05:12 AM
ml258
09-18-2008 03:14 PM
yesnyes
04-19-2008 12:26 PM
Quick Reply: Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE
