Sponsored by:
Sponsored by:
06 Camry Right Rear Noise
Old 03-17-2012, 11:16 AM
tjm7's Avatar
Default 06 Camry Right Rear Noise
My 06 Camry has been making a funny noise now and then coming from the right, rear wheel. The weird part is that it will be there for maybe a day or two, and then nothing for months. I just changed the tires and it's back. I think it might be something that is loose, occasionally hits the rotor or something, and spins around a bit. Then maybe by chance it gets jammed up so the noise disappears for a while...
Before I take the wheel off and disassemble stuff to go looking, I recorded the noise in the following sound clip (sorry for the poor quality):
Camry rear wheel noise by tjm7 on SoundCloud - Create, record and share your sounds for free
Any help is appreciated!
Old 03-17-2012, 02:31 PM
Check if splash shield behind the rotor is rubbing on the rotor. It can get bent and rub.
The rear rotor incorporates a brake drum for the emergency brake,, determine if a shoe or a retraction spring is rubbing on the drum.
marblehead2006
05-29-2016 08:41 PM
browncamry
03-20-2013 02:52 AM
DROB
09-05-2012 10:13 AM
red73mustang
03-26-2008 07:42 AM
idreos
07-24-2006 10:25 AM
Quick Reply: 06 Camry Right Rear Noise
