Clicking noise - right front
I have a 2001 2.2 Camry that makes a "clicking" sound on the passenger side in the front. It sounds like it could be a loose suspension componant ,but I think it goes away somewhat after the car gets warm (or I just don't notice it). Any ideas would help.
Thanks, Chet
[align=right] [/align]
Thanks, Chet
Is this a constant clicking noise even when the car is not moving?
Use a section of rubber hose as a stethoscope and attempt to localize the area. Places to check are the A/C compressor pulley, alternator, PS pump, belts, timing and valve cover areas.
I would venture to guess that the noise is caused by a worn CV joint in your front axle. If you have a significant number of miles on the car it could be worn out and need replacement. Replace both axles at the same time.
Another cause of CV (Constant Velocity) joint failure is a broken rubber boot that covers the joint. If the boot is cracked/split/torn it will let debris in and lubricant out causing failure.
Get under the car and examine the axle boots. If damaged, replace. If you cannot do that then take it to a mech for them to examine. Axle replacement is on the order of $150.00 at most smaller shops.
axlman
Jul 2, 2012 05:48 PM
flpalla
Oct 6, 2010 09:48 AM
jbishop1
Aug 20, 2007 12:50 PM
