Sponsored by:
Sponsored by:
1992 AC condenser repair
Old 02-28-2007, 11:44 PM
Good Times's Avatar
Default 1992 AC condenser repair
I have a 1992 Camry V6.The AC Condenser needs to be replaced. How much of a job am I looking at?? Does the radiator have to be taken out to remove the Condenser, and replace it with a new one.??Haven't had a chance to see what I'm getting into. Can I get instructions on line about this repair?? Thanks for any, and all help.
Old 03-11-2007, 11:54 PM
tim96460's Avatar
Default RE: 1992 AC condenser repair
To me that is a money maker. Not that tough of a job but be very clean when handling new parts especially the exspansion valve, I mean if you replace the condensor replace the expansion valve allso. Use new ac compressor oil on all new o-rings and don't reuse any!! Besure to replace the reciever dryer allso as if the system has been depleted of r-12 is will surly be saturated with moisture wich is very bad. Before you close the system up add about 2 ounces of r-12 compliant compressor oil or if you retrofited with the r-134 make sure it is the synthetic oil. Evac for about 20 minutes then charge system. Failure to not do what I have said will more than likly fail before the summer, good luck.
[align=left] [/align]
Old 03-11-2007, 11:57 PM
tim96460's Avatar
And no the radiator stays in car, work is performed via the passenger side
Old 03-12-2007, 03:01 AM
toyoboy's Avatar
are you certified to handle r12? and have the right equipment. ?
Old 03-13-2007, 01:39 AM
tim96460's Avatar
Yes and have been for 20 years maybe(cert), been a while. I do most of the A/c work at the shop. Likle I said ac work in a real money maker, anyone can do it just a few key things you have to remember.
Old 03-13-2007, 03:28 AM
toyoboy's Avatar
I was replying to good time... but i do like your motorcycle... ihad a cbr once.
Old 03-13-2007, 09:43 PM
jasmtz531's Avatar
ORIGINAL: tim96460
[align=left][/align]
A/C is always gravy work. At my shop we got evaporators down to like 2-3 hours when we tag team it. It is getting pretty warm out so the A/C problems should start rolling in pretty soon... I was 16 when I got my A/C cert. But that was only 2 years ago so I havent really had the time to really benefit from it. Are you a Toyota Tech by any chance??
And Good Times - You have a PM, should help a bit.
Old 03-14-2007, 06:06 AM
tim96460's Avatar
I am all Japanese Tech. Why limit yourself to one make, You mentioned tag team, that is a dealership slang, r u?
White Phoenix
08-29-2012 10:55 AM
stone4779
04-14-2012 12:58 AM
bslevy3477
10-09-2010 06:42 PM
justinw
07-11-2010 06:44 PM
axlman
06-28-2007 02:58 AM
Quick Reply: 1992 AC condenser repair
