Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 09-14-2008, 05:45 AM
Default Check Engine & Flashing "O/D Off" light
My Check Engine light came on today and the Overdrive Off indicator is flashing. From what I have read about the O/D Off indicator, it means there is something wrong with my transmission. I'm going to be taking my car to a mechanic to get a quote... what I'd like to know are some of the things I should be familiar with. I'm not a car guru, and I'd like to have at least a little idea of some of the possible problems that could arise from this. I suspect it's not good. I have a toyota camry, 94', 240k miles on it, kept up very well. Any tips on possible problems? Information I should be familiar with before I take it in? Should I expect this to get costly? Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 09-14-2008, 09:51 AM
Default RE: Check Engine & Flashing "O/D Off" light
Flashing O/D light means an electrical problem with the trans - usually solenoid not shifting or speed sensor. Does the trans operate ok? Does it shift through all gears, even OD? Could just be bad solenoid or broken wire, not necessarily expensive. The O/D codes can be accessed easily to narrow down the area to look at, your mechanic should know how to do this.
__________________
95 2.2L LE Wagon Auto Trans 150,000 miles.
Old 09-14-2008, 03:13 PM
Awesome! Thanks for giving me some hope. Yes, it operates fine, I haven't noticed any issues. I haven't tried all the gears, but I did try overdrive and I can feel the difference... everything appears to be fine. I'm going to try to take it to the mechanic Monday morning and see how serious it is. I suspect they should be able to know and give me an accurate quote by reading the error codes off the check engine light and O/D Off... right? eg. there shouldn't really be much unknowns, in other words. Anything else I should know is greatly appreciated... otherwise, this seems straightforward based on the error codes.
Old 04-08-2011, 12:39 PM
Default Same Problem-flashing OD light and engine light turns on
I am using a Camry 2001. I am currently having a similar problem. Can u tell me what was the reason for the problem and your solution. Thanks.
submit to reddit
Tags
05, 92, 94, blinking, camry, check, engine, flashing, indication, indicator, light, means, od, oo, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
