Sponsored by:
Sponsored by:
Old 09-01-2015, 02:54 PM
How-Tos on this Topic
Browse all: Interior Guides
Print Wikipost
Gas Cap Panel Won't Pop Open
Old 03-30-2009, 10:09 AM
T.K.'s Avatar
Default Gas Cap Panel Won't Pop Open
I just purchased this 1998 Camry LE over the weekend, and finding things wrong with it that I never even thought to check out prior to buying (private party, didn't tell me).
The gas cap panel won't open when I pull the release! The lever just doesn't "engage" anything. I need to get this repaired before I can fill up.
My question is: How big a problem will this be to repair, and approximately how much might it cost to have it fixed? I already know that a dealership will automatically triple that estimate, but would like to have some number in mind for reference.
Thanks, T.K.
Old 03-30-2009, 03:02 PM
Is the leaf spring in the gas cap lid broken? Can you have someone pull the latch while you open the lid?
If it is the spring this is a common problems and low cost DIY repair, the dealer would have the spring.
Old 03-30-2009, 07:04 PM
T.K.'s Avatar
Yes I can open the cover if the lever is raised. I used a bicycle rack stretch rope, wrapped the hook around the lever, held the other end while pulling back, reached for the gas cap panel and pulled it open with a thin wire hook.
I guess necessity is the mother of invention, but how would this look if I were on a date with someone and needed to gas up? (lol).
Must fix soon! Thanks for your reply, T.K.
Old 03-31-2009, 12:27 AM
Joel_CA's Avatar
Exactly- it just snaps into place near the hinge of the fuel door. Good luck!
JJ
rangermenace
03-12-2012 10:41 PM
awbooth
05-23-2010 08:19 PM
GTScott
02-25-2008 11:29 AM
BlackMage
11-30-2006 05:10 PM
cmrylovr
07-30-2006 05:10 PM
Quick Reply: Gas Cap Panel Won't Pop Open
